Hi there I am assuming your new TV is now Digital. If so, it will be looking for a different signal to the old TV which was probably analogue. You may need a aerial upgrade/diagnostic to determine if you are recieving a digital signal. Or you can tune in the analogue channels, by switching the new TV to analogue, through the inputs/menu, and then i suggest autotune. Hope this helps TV_Doctor
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using. If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
I have solved the problem by selecting Manual Tune in the Menu. This means selecting each channel one at a time beginning at 21. The indicator shows the Signal Strength and Quality for each channel. If both show a green bar (strong on both counts) give it time to identify the new programs on each channel and add them. It will show how many found and added if you wait a few minutes. When each channel is done, move on to the next one. The last channel is 65 I believe but there is not much up the top end.
When I had finished going through this routine I found it had indeed added all channels I needed including BBC1 and BBC2
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
