Danby DPAC8020 Air Conditioner Logo
Posted on Aug 13, 2009
Everstar Model MPK-10CR, What does flashing P2 mean?
I have a manual and it only talks about the error, P1, when the water container is for. Says nothing about P2. The unit will just completely shut off and then the red light is flashing and P2 appears in the window.
  • oyalajan Aug 13, 2009
    No, I do not add water to the unit.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8760
Points
10
P2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
  • jerry1029 Jun 14, 2011
    My unit runs for about 5 or 10 minutes then shuts down blinks red with the P2 error message. I read what has been said but there is no water built up in my unit. i removed the plug , nothing. it does not run long enough to fill up. any ideas?
  • Anonymous Jun 12, 2013
    my unit is flashing p1 my unit is flashing p1 what is wrong
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10274
Points
6
The filter that allows the water to get to the pump is clogged. Since the pump can't pump the water into the drain bucket, it fills the bottom pan up, the unit shuts down, and the P2 error code is then displayed.
  • 1 more comment
  • oyalajan254 Jun 30, 2011
    Where is the filter that is full that is not allowing the water to drain into the drain bucket, and is it something that can be cleaned?
  • Anonymous Jun 30, 2011
    It should be near the pump that pumps the water up to the drain bucket. Each model is different, on my Everstar it was located under the housing for the drain bucket. The back and front of the unit needed to be removed, then the housing for the drain bucket needed to be removed. Not that hard, but a lot of screws. Take it out, then clean it with some dish washing detergent.
  • John Ahrens Aug 11, 2018
    where is the bottom drain plug located everstar mpk-10cr error code p2?
What is P2 indication on my everstar MPK-10CR-1?
Prior FIXYA question:
http://www.fixya.com/support/t2766014-everstar_model_mpk_10cr_flashing_p2
Everstar Model MPK 10CR What does flashing P2 mean
Quoting:
Posted by oyalajan on Aug 13, 2009
zobs
P2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle Posted on Jul 21, 2010
  • gerald young Jun 12, 2013
w_benjamin
The filter that allows the water to get to the pump is clogged. Since the pump can't pump the water into the drain bucket, it fills the bottom pan up, the unit shuts down, and the P2 error code is then displayed. Posted on Jun 29, 2011
    Where is the filter that is full that is not allowing the water to drain into the drain bucket, and is it something that can be cleaned? w_benjamin Jun 30, 2011
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
1helpful
2answers
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
12helpful
2answers
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
21helpful
4answers
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
