F 02 error means that is Clogged drain filter.
Remove lower front panel, Torx driver required. Open the filter, the front cover spins off. Remove baby sock, dog hair, and fibers from curtains and replace cover. Mount front panel, set washer down. Plug in and test.
Was this helpful?
please rate my assistance
thank you
Not only was this comment 'helpful'...but by following the directions, I was able to save myself a service fee of $80-$100 to fix the problem.
Not only was this comment 'helpful', but by following the directions, I was able to save myself a service fee of $80-$100.
Simple and effective. Our problem was a washcloth stuck in the drain hose leading to the filter. With a little massaging and this advice we saved a service call and my wife thought I was a hero! Now if everything were this easy life would truly be great! Thank you!!!
thanks a lot it was a baby sock underneath the rubber gasket blocking the drain holes
Worked like charm, mine was plugged shut. I had it up and running in under 5 minutes.
Hello & Welcome to FixYa
F02 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
F02 is a drain error in your Kenmore washer, if
other questions.
Kevin
