Televison & Video Logo
Anonymous Posted on Aug 13, 2009
No picture on a hitachi 42edt41
My hitachi 42edt41 tv will power up but when i do there is no picture what so ever.
  • 1 more comment
  • Anonymous Aug 14, 2009
    i have sound but no picture, so what inverter would i need to buy?
  • Anonymous Aug 16, 2009
    i looked through there but i could not find an inverter.
    thank you very much, but unfortunetly it was not on that site either.
miguelalvara
Level 2:
  • Expert 109 Answers
  • Posted on Aug 13, 2009
miguelalvara
Expert
Level 2:
Answers
109
Questions
0
Helped
39661
Points
301
Do you have sound but no picture or you dont have sound and picture? if you have sound you need to buy the inverter but if you dont have sound and picture you need to buy the main board
Testimonial: "very helpful!"
  • miguelalvara Aug 15, 2009
    hello you need to buy the tv.inverter.click at www.shop jimmy.com
    they can give you the rigth inverter for your tv.or you can call at
    1877-881-6492.
  • miguelalvara Aug 16, 2009
    Hello if you dont find the tv inverter in shop jimmy tried at
    www.partstore.com just click at that page and write your brand
    and your model # just put inverter in search ok. and if you want
    to save money you can change the part your-self or click at
    www.lcdparts.com they give you instruction how to do it
Red fuzy screen
You had not fixed all connector properly.
The screen on my Hitachi 42EDT41 went blank. I still have sound, but no image. POssible problems/solutions? Thank you!
This is a common plasma tv problem. I changed the Y-sustain board and the Z-sustain board and that fixed my "sound, but no picture" problem. You can find both boards on ebay; the Y-sus board is around $100 and the Z-sus is around $50. Hope this helps.
1helpful
2answers
I have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
2helpful
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
My hitachi 42edt41 42in picture flickers
First. Try using a surge protector.
Could also try purchase a HDMI cable that is compatible with 100Hz,
Possible problems:
backlight inverter wearing out
Very Common In The Newer Tv Sets
Tv's have a chemical/molocules called phosphors that can be deentergized when a tv is left on for a long period of time. Not a serious problem but still annoying
Hitachi 42edt41a no picture help
Bad buffer board, Let me know if I can help. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
2answers
Hitachi 42edt41 problem
sir maybe theres something wrong with its power suply,,,,kindly check it out,,thankss and hope too help you??
From max tv
ok is the monitor u need to replace the lower board of the tv and thats it and u are done enjoy
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
