Question about Kyocera FS-C5030N Led Printer
Set up KYOCERA FS-1350DN printer
How can I set up the above to take the 1st page from the MP tray and the 2nd page from tray 1?
    Sniper:
  • 62 Answers
You need to scroll thru your menus...paper handling section...make sure mp tray is set to FIRST..that way it will pull from the mp tray untill it is empty than switch to your cassette
Posted on Jan 06, 2010
6ya staff
SOURCE:
Where is the MP tray?
It's the small door at the very front of the machine...located directly above the main paper feed tray. Just pull it open and lower it down. MP stands for Multi-Purpose and is for different paper types and sizes that are not available from the main tray.
Oct 12, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Oct 14, 2008 | Kyocera Office Equipment & Supplies
Colour band at base of page
Check for the latest print driver and eventually for the latest firmware. You may have to switch the print driver to PCL instead of KPDL (Auto). Ask your service provider to do that if you don't have the knowledge.
Jul 29, 2008 | Kyocera FS-C5030N Led Printer
Kyocera FS-C5030N Led Printer Logo
1,030 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
