Vacuums Logo
Danise Flanders Posted on Jun 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dyson vacuum belt slips won't stay on beater brush, is it possible that it has wrong belt?
Thatvacguy.com
Level 3:
  • Dyson Master 1,619 Answers
  • Posted on Jul 14, 2019
Thatvacguy.com
Dyson Master
Level 3:
Answers
1619
Questions
0
Helped
605057
Points
3345
Yes, It is possible
5 Related Answers
Anonymous
  • Posted on Dec 28, 2008
SOURCE: Dyson Animal dc07 -- change belt
Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
Anonymous
  • 7 Answers
  • Posted on Apr 18, 2009
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Anonymous
  • Posted on Aug 23, 2009
SOURCE: ratchet noise, beater will not turn, belt not
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Anonymous
  • Posted on Nov 22, 2009
SOURCE: my dyson vacuum brush bar will not rotate and the
I took the plate off and cleaned up the vacuum brush bar. Since the belt was not broke I knew that was not the problem. I know when the setting is bare floor, the brush bar will not rotate. That was not the problem. I just keep turning the knob from bare floor to carpet, several times. The setting must have been "off" just a bit because after several times turning it, it must have reset in the proper setting. The brush bar did start rotating just like normal.
Anonymous
  • 231 Answers
  • Posted on Feb 27, 2010
SOURCE: Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
1helpful
My dyson beater bar is spinning but no longer touches carpet surface to pick up hair or thread .There is still plenty of suction. If I ever so lightly place my hand on the top of the beater brush it works...
Brush rolls wear out and usually need replaced every few years. The DC33 model has a clutch with belts which could also be slipping. I would replace both of them
Have a sour odor when the vaccum is running. What could be the problem? Best way to describe the smell is that is smells like dirty feet. I have the dyson dc07 Pink
Either something you have pulled into the vacuum or perhaps the drive belt is not turning the beater brush. Remove the beater brush and clean as best you can paying particular attention to the end pieces. If possible, squirt a bit of WD40 between the beater brush and the end pieces. Turn by hand to be sure the brush is moving freely. Reassemble with new belt.
Please let me know how it turns out. Paul
2answers
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Belt drive not working. Won't turn beater brush.
You need to replace the belt. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
2answers
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
1helpful
2answers
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
1helpful
Dec 27, 2008 • Vacuums
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
