I DID A LOAD AND WHEN I STARTED TO DO THE NEXT LOAD IT STARTED FILLING THEN STOPED. i CHECKED IT IN HOT & COLD, NOTHING. IT HAS POWER BECAUSE THE SPIN CYCLES WORK.
Try filling it on another cycle and see if it works. Normally when this happens its the switch going bad (the knob selector) and needs replacing or the fill sensor that tells the machine to shut off the water when the level gets to a set height Also try truning it very slowly to see if the water trys to fill.
Hi, it's possible your water solenoid valve burnt out, where your hot and cold water enter machine, fill washer with a bucket, careful don't overfill, if machine start, then it's your water solenoid valve, burnt out, replace it. if machine did not start, then it could be, your water temp, switch, try cold/cold wash, do not select hot &cold or warm/cold, select cold wash and try machine. let me know what happened. good luck.
Hi, replace fuse with, same type fuse( amps), using foil paper could cause other problem, damage other parts, your motor pulling to much amps, check capacitor for motor could be faulty, is your room temp. high ? could be low voltage. or voltage surges, motor gets to hot, so it pulls more current (amps) leave machine to cool for about 1 hr, then try it, be careful don't over load it. let me know what happened. good luck'
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
I found the fuse blown and replaced it. it kept blowing I checked the lid switch ch and it needed to be replaced and did so. I started a new wash and it was fine upto the rinse cycle and it blew the fuse again.(maytag LSE7806ACE)
I found the fuse blown and replaced it. it kept blowing I checked the lid switch ch and it needed to be replaced and did so. I started a new wash and it was fine upto the rinse cycle and it blew the fuse again.(maytag LSE7806ACE) and again.
I put a peice of foilaround the fuse and the was times through the whole cycle to spin but the rinse cycle doesn't work
Why did my LSE7806ACE WASHER STOP FILLING
I did a load and when I started to do the next load it started filling then stopped. I checked it out in hot & cold, nothing. It has power because the spin cycles work.
I found the fuse blown and replaced it. it kept blowing I checked the lid switch ch and it needed to be replaced and did so. I started a new wash and it was fine up to the rinse cycle and it blew the fuse again and again. I put a piece of foil around the fuse and the was times through the whole cycle to spin but the rinse cycle doesn't work
(Maytag LSE7806ACE)
I found the fuse blown and replaced it. it kept blowing I checked the lid switch ch and it needed to be replaced and did so. I started a new wash and it was fine up to the rinse cycle and it blew the fuse again and again. I put a piece of foil around the fuse and the wash times through the whole cycle to spin but the rinse cycle doesn't work
(Maytag LSE7806ACE)
