Televison & Video Logo
Eugene Wood Posted on Jun 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to scan a RCA led 32c45rq - RCA Televison & Video
Franco Dosil
Level 3:
Top Expert:
  • RCA Master 10,542 Answers
  • Posted on Jun 22, 2019
Franco Dosil
RCA Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378730
Points
178965
Hi Eugene, I sent you the link to download the user manual for your RCA and follow the steps to program it
Hope this can help you
Greetings Franco Dosil
Hola Eugene, te env?o el link para que descargues el manual de usuario para tu RCA y sigas los pasos para programarlo
Espero que te sirva
Saludos Franco Dosil
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&thid=27690180#
http://www.specsserver.com/CACHE/FRUBOVYUEHOV.PDF
Just bought rca hd led tv and we can not get it to recognize the cable box signal. Keeps prompting to run auto scan
Press input on the remote use up down keys to select cable box signal ,usually AV. press ok.
1helpful
RCA TV switching on and off
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
1helpful
Just purchased an RCA 32" LED TV from K-Mart. Trying to set-up and in auto-scan it will not pick up any channels
It really depends on how your connecting signal. I am not sure about where you are but virtually all cable companies in Canada require the use of the cable box. Searching channels will only check either the analog cable input or rabbit ears. Typically you hook up the cable box via HDMI and set the televsion to that HDMI input and channels are changed on the cable box.
My RCA HD LED 32 IN TV WON'T TURN ON
Power supply board has a problem. Parts can be has online at shopjimmy web page
New LED tv will not pick up digital channels
Refer its user manual, and make sure that the TV can receive digital transmissions. Refer its specification page. If it says, yes, and the TV doesn't receive any digital channels, contact the authorized service center. Its digital tuner is likely to be faulty. Gopakumar Gopalan Google
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
