I have a Compaq nc6230 and when I try to put the SD card into the slot marked "SD", the slot seems to big. I try to put the SD card in and it will not click or do anything to lock in.
Re: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
The GL2 works with SD cards. Your 16GB card is an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to use an SD card, 2GB or smaller.
Ok my friends, in this moment I'm fixing this problem in a compaq nc6230...The problem here is....The keyboard!! Try uninstalling your keyboard, and now turn on without the keyboard, and now you can see the message of "Insert Smart Card" dissappear!!
The G500 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
First Format your SD card and Try it. If this doesnot work, Check with your phone dealer that the SD card memory capacity can be used. Some phone only accept memory card upto 1GB.
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
You tried to put a Sony Memory Stick into an SD slot? It will probably need as much force to pull it out as it took to jam it in there!
I'd power off, and start with tweezers... if that doesn't work... i'd break out the needle-nose pliers. You may break the reader while trying this... but a card reader is all of $10-20... and you're kinda stuck anyway. ;o)
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
