Question about Frigidaire Refrigerators
I have a brand new frigidaire counter top icemaker EFIC108 filled it up with water plugged it in theon button is flashing will not let me choose sm or lg size,help
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: Kenmore catalyst SM 9710768-D
pls check lid switch operation
Posted on Aug 16, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
David Coomer
  • 1073 Answers
SOURCE: frigidaire frs26zthb3
icemaker is iver filling and running down through the freezer, some of the water runs out into the floor since the door gasket does not provide an water proof seal just an air tight seal
the ice maker can be adjusted, remove the cover off the frount of the icemaker and back the screw on the right side so that the indicator in the middle is twards the minus sign and you need to clear the frozen water out of the freezer drain pan so it can go to the drain pan down at the compressor
it might take a few adjustments on the ice maker to get it right
Posted on Apr 30, 2008
vegassurveyo
SOURCE: KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Posted on Dec 05, 2008
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
No water to the ice maker .I took out the cover of ice maker turn by hand the wheel after one cycle .I heard the sound and water filling up ice maker but when it become ice for long time .the ic
Hi friend, thanks for your post!
I understand that your icemaker on your Frigidaire refrigerator is not getting water to the icemaker. It sounds like you could have an issue within the valve or solenoid. I would recommend having a professional come out to properly diagnose your appliance and repair it. -Matt
Sep 17, 2014 | Frigidaire Refrigerators
Frigidaire icemaker still overflowing after replacing inlet valve
Make sure the water is not splashing out the fill tube rather than the icemaker. Sometimes ice forms in this tube and causes the water to shoot over the tube and run down. You could also try turning the water faucet valve down a bit. Your water pressure could be too high and it is filling too fast. Last thing if you have very hard water the cubs could be sticking in the mold tray and not releasing. When the icemaker fills again there is still ice in ther causing the icemaker to overflow.
May 17, 2014 | Refrigerators
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
My side by side refrigerator is making a buzzing noise from the ice maker area every few minutes
That sound you here is the icemaker calling for water to fill the icemaker but not water into refrig to fill icemaker. If you have no water connected to icemaker,lift up and lock arm into place to turn off icemaker,if you do have water line connected but no ice is being made need to see why water from house plumbing is not coming into the refrig.
Gene
Aug 11, 2011 | Frigidaire Refrigerators
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frozen water tube that goes into the icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 21, 2008 | Frigidaire SUPER SPECIAL 22.6 cu ft...
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
