Ice is working so water line seems to beok but water does not comeout from the front water dispencer. I don't hear the motor working, so where is the motor in the refrigerator. I have Kenmore refrigerator about 9 years old.
When you try the water dispenser you should hear the water inlet valve which is on the back where the water supply comes in. If you do hear it then Your
water line could be frozen in the door. You can disconnect the line under the
unit before it goes into the door at the bottom hinge. Push the dispenser
button and see if it comes out there. If it does leave the door open till it thaws.
If you don't hear the valve working the dispenser switch is bad.
Compressor is under the fridge at the back. Water line works since ice maker is working. When I press the water latch I don't hear the motor, so I am not sure if the line is frozen or motor is bad.
check inlet valve and what motor do you mean ...the compressor is under the fridge at back
