Question about Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System
DVD stuck in Samsung blue ray player.
I have the same problem but after unplugging, replugging and trying to open is it still stuck.
I have tried the Samsung support troubleshooting and it has not worked. Can you help?
6ya staff
SOURCE:
Anonymous
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Posted on Jul 23, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: We have a samsung blue ray player BD-P1400. We've
http://www.samsung.com/us/support/download/supportDown.do?group=mp3audiovideo&type=blu_ray&subtype=blu_raydiscplayers&model_nm=BD-P1400&language=&dType=D&mType=FM&vType=R&prd_ia_cd= This is the link to Samsung for firmware updates. All manufacturers have had several updates moving on with disc technology. If you can't burn this to a disc as data, then email samsung and they will send you an update disc. Next, if you don't have one, get a Laser Lense Cleaner. Preferably one that uses liquid, and run that thru a couple times. Clean your players often! it's a good habit to get in to. Hope this helps
Posted on Jun 11, 2009
Derek Williamson
  • 40 Answers
SOURCE: I have bouight a samsung home theatre system that
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Posted on Jun 19, 2009
Anonymous
SOURCE: Need vizio code for Samsung remote!!
Start with code 19. If it does not work try all the Daewoo codes..
Posted on Jan 09, 2010
Tee Jay
  • 6 Answers
SOURCE: Why does my samsung Blue Ray DVD player load to
Just need to verify if your trying to play a Bluray Disc or regular DVD?
If Bluray Disc:
All you need to do is to check on the FW version of you BD player. Go to Set-up > System > System Information. SW will be the FW version info. Please be informed that the latest FW version is v2.12. If it will not resolved the concern, try to verify if its happening to all of your Bluray Disc.
Sincerely yours,
Genius 101
Posted on Oct 23, 2010
Zenith xbr616
its the close/open button, it is stuck . unstuck it by playing with it or by opening your unit.
ynx 4 using fixya,
drcool
Sep 13, 2008 | Zenith XBR616
My dvd is frozen it is on eg power is on but It wont turn off or eject the dvd in it whatcan I do
UNPLUG POWER REPLUG PRESS POWER AFTER PRESS POWER IMIDIATLY PRESS OPEN 2-3 TIMES TRAY SHOULD OPEN THROUGHT THE DVD IN THE GARBAGE !
Dec 19, 2010 | Samsung DVD-R130 DVD Recorder
Blu ray player will not play any disk. Player stays in "load" mode. Open an close controls do not work. Have unplugged and replug. Player tries to load even without a disk in the player. Wireless...
Try to clean your player with a lens cleaner. Insert the cleaner to the player for 3 minutes or until cleaning process is done. If you don't have lens cleaner use a cotton buds with alcohol to clean the lens. Open the cover of the player and dismantle the upper assembly that protects the player. Using the cotton buds clean it with extra care.
Nov 29, 2010 | Samsung BD-P3600 Blu-Ray Player
When i try to put a dvd on the blu ray gets stuck on load and the screen is just on a bubbly blue screen
try disabling "CE Link" communication between the TV and Blu Ray player. see this link
http://forums.cnet.com/5208-13973_102-0.html?threadID=347242
Aug 09, 2010 | Samsung BD-P1600 Blu-ray Disc Player
The word PROTECT appears on front of player cant do anything
Unplug the Bluray Player for an hour,replug should reset it self.Should have normal functions.
Feb 03, 2010 | Samsung BD-P1500 Blu-Ray Player
DVD player will not open
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
Dec 14, 2009 | Toshiba SD-K860 DVD Player
DVD stuck in player, drawer won't open, any suggestions?
Unplug,replug about an hour later should be back to normal reset to factory setting.It should open and close ur DVD tray again,if ur motor is not burn or dead.
Dec 10, 2009 | Televison & Video
Blue ray disc broke my dvd player
Unplug/replug the player - try again.
Also, get a firmware upgrade disc from Sony's website to try and reload the firmware.
Sep 04, 2008 | Sony DVP-NC615 Multi-disc DVD Player
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System Logo
376 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
