Kenmore 84152 Electric Dryer Logo
Posted on Aug 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Model DBXR463ED2WW TAKES A LONG TIME TO HEAT UP AND DRY CLOTHE
I have the same problem. I have a GE mod dbxr463ed2ww it takes about 3 hours to dry a load of laundry. It takes a long time to heat up to dry the clothes. Could you tell me what is wrong and what has to be replaced on it. It is only 4 years old.
Anonymous
Level 2:
Sergeant:
  • Expert 193 Answers
  • Posted on Aug 14, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
193
Questions
0
Helped
56214
Points
572
Probably needs a new heater coil
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
1helpful
My GE Dryer Model # DBXR463ED2WW makes loud squealing sound when it runs loaded. Is this something I can fix?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
I have A ge DBXR463ED2WW .it takes about 80 minutes to dry A load.dryer seems to only have A fourth to half heat.
This could be the clothes are coming out of the washer wetter than normal, or poor air flow. 80 min in a little long but a lot depends on the wetness and amount of clothes. If the vent system is clear then I would try smaller loads and checking the washer.
Eric
1helpful
GE DBXR463ED2WW Dryer Turns on unexpetedly
either the timer switch/control is defective or you have a broken or intermittant neutral wire and its backfeeding that open circuit to find another current path and this will trigger very strange operational issues
1helpful
Electric GE dryer DBXR463ED2WW is not drying
The exhaust hose or piping is clogged, try cleaning it or replace it.
Mar 26, 2009 • GE Dryers
1helpful
Bad heat in two year old GE DBXR463ED2WW electric dyer. Not as hot as used to be, takes longer to dry!
If you're experiencing a dryer that requires a longer time to dry, you may want to view this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the first major paragraph. I know the link is for a no heat problem, however, if you have a dryer that is starved for air, the heating circuits will eventually fail. In most cases, a no heat, or longer dry time problem is directly associated to clogged ventilation, kinked dryer vent hoses, improperly installed vent ducting, a clogged blower fan assembly, or rodents. Yes...the last one isn't always fun, but I have found bird nests, mice nests and even snakes inside dryer vents, clogging the air flow. The symptims were all the same - a dryer that would not dry properly. Before you assume you have a component going bad, take a good look at the way your dyrer is installed and inspect it thoroughly for what might be a good cleaning. The outsiode dryer vent should be at least 12 inches off the ground and a louver is recommended to cover the end to prevent critters from getting inside. In addtion, the SHORTER nd STRAIGHTER the dryer exhaust vent is, the better. If you have an exhaust vent with excessive bends, or excessive run length, this can contribute to poor heating of the dryer. Especially exhaust vents that run thorugh an attic or under a crawl space. They typcially develop sags, which create choke points where lint can accumulate to the point where it clogs. I do not know what your situation may be, but provide this as some helpful guidance just in case. I hope you find this information helpful. If you inspect your dyer and still have problems, please post back and let me know.
Sep 03, 2008 • GE Dryers
3answers
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 • Dryers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
