I'm having trouble with the clarity of close pics, can you help me with the best settings to use to take close-up pictures ?
Thanks
Jim
Look for a button or setting that looks like a small flower. If there is one on your camera it will set up for close ups to about 7 inches. When done press the button again to clear the setting. The button may cycle through several different settings so you may have to press it multiple times to access the close-up mide.
Testimonial: "Thanks for that. I did have the macro set, but I seem to get very poor quality, blurred results when trying to get a decent pic in close-up!"
you do one thing , you select image from your PC ..right click on it & go to its properties,uncheck read only & hidden option & then trfr this image to your h.set .most probably you will be able to trfr that pic to other phone.If you are successfull in doing so ,then you need to trfr all images again in the same manner .
sometimes if you have hidden any image in PC or have clicked read only.then after trfrng that image in your h.set you are not able send them to other phones.
