Toshiba Master
- Posted on Aug 14, 2009
Re: Toshiba 57h81 with sound and no pic? no menu but guns...
After the set has been on for 20 min., the heat sinks on those should be nice and warm. If they are then if you have a stand-up video I/O board with plug in jacks, make sure it is seated properly.....Try this first and let me know.
ok checked out ok, alittle loose but they all are flimsy..i removed that board when i replaced stk's..also after replacing stk's i had the famous flash focus error..but i converged all corners with remote manually..and only the visual went out is when i removed the screen to clean the back of it and mirror..no overspray and didnt touch the sensors??any help is greatly appreciated..thank you in advance
