Printer won't pring and gives the error message "laser unit polygon motor failure".
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Another solution is to replace the polygon mirror/motor if you are handy. ** do this in a dust free place **
If you have another laser unit that had a problem other than the polygon motor, pull the unit from it with this procedure.
It is located underneath the laser with 3 screws and goes to the small connector. Cut all cable ties and remove black backing. Remove screws from both units. Swap polygons quickly and replace screws.
Tape up areas where you remove the black facing. Cable tie the cables and install the laser ROS unit as per service manual.
Turn on printer and clear TechRep faults if needed as per manual.
Perform REGICON procedure. (I checked the print quality closely and didn't need it)
.... and you are done. Saved me many $$$$
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
u2 laser unit failure
