Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Aug 14, 2009
LDAP issues with Konica C451 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Anonymous May 11, 2010
    Enabling LDAP Select whether or not a connection is established with the LDAP server and the LDAP function is used. 1 Touch [5 Network Setting] in the Administrator Settings screen. ? For details on displaying the Administrator Settings screen, refer to "Displaying the administrator settings screen" on page 4-7. 2 Touch [6 LDAP Settings] in the Network Settings screen. 3 Touch [1 Enabling LDAP]. The Enabling LDAP screen appears. 4 To use an LDAP server, touch [ON]. 5 Touch [OK]. ? To cancel changes to the settings, touch the menu item name in the Bookmark screen to return to the selected screen without applying the changes to the settings. Use of the LDAP server is specified.
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Aug 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
94245
Points
90
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
  • Anonymous Aug 30, 2009
    Network settings 5
    Setup LDAP screen 5/6
    Setup LDAP screen 6/6
    All screens
    LDAP screen 6/6.
    User Authentication: If a user is logged on to the copier with external server authentication,
    the user name used with external server authentication is automatically
    entered in the LDAP server logon screen.
    Dynamic Authentication: When using the LDAP search function, a user name and
    password is requested.
    Referral Setting Select whether or not the referral setting is used.
    If referral is used, the search base that was specified in the LDAP server settings
    searches the upper and lower levels as the starting point.
    Login Name Specify the logon name for connecting to the LDAP server. Use the keyboard that
    appears in the touch panel to type in the logon name (255 characters or less).
    Password Specify the password for connecting to the LDAP server. Use the keyboard that
    appears in the touch panel to type in the password (128 characters or less).
    Domain Name Specify the necessary domain name for connecting to the LDAP server. Use the
    keyboard that appears in the touch panel to type in the domain name (64 characters
    or less).
    Check Connection Touch this button to check the connection to the LDAP server.
    Reset All Settings Touch this button to reset all LDAP server settings to the defaults.
    If a message appears, requesting confirmation to reset the settings, touch [Yes].
    5
    Network settings
    5-54 bizhub C650/C550/C451 (FE3)
    – For details on displaying the Administrator Settings screen, refer to "Displaying the administrator
    Touch [2 Setting Up LDAP].
    The Setup LDAP screen appears.
    Touch the button to be programmed and where settings are to be specified for the LDAP server.
    Setup LDAP screen 1/6 appears.
    bizhub C650/C550/C451 (FE3) 5-55
    Network settings 5
    5
    Specify the desired settings.
    – To specify the initial search conditions in an advanced search, touch [Initial Setting for Search
    Details]. Select a condition and its setting.
    – Select the default condition ("OR", "AND", "START" and "END").
    – The specified conditions can be changed when a user performs an LDAP search.
    6
    Touch [Forward ].
    Setup LDAP screen 2/6 appears.
    7
    – [Check Connection] appears only if "Enabling LDAP" (displayed from the LDAP Setting screen) is
    set to "ON" and "Manual Destination Input" (displayed on the Security Details screen) is set to
    "Allow".
    8
    Touch [Forward ].
    Setup LDAP screen 3/6 appears.
    9
    10
    Touch [Forward ].
    Setup LDAP screen 4/6 appears.
    11
    – Select the authentication method that is used by the LDAP server being used. For details, refer to
    the manual for the LDAP server being used.
    – If "GSS-SPNEGO" is selected as the authentication method, type in the domain name of Active
    Directory.
    – Depending on the selected authentication method, a connection check cannot be performed if the
    following settings are incorrectly specified in Setup LDAP screen 6/6.
    – For "Simple" and "Digest-MD5": Login Name
    – For "GSS-SPNEGO": Login Name and Domain Name
    12
    Touch [Forward ].
    Setup LDAP screen 5/6 appears.
    13
    bizhub C650/C550/C451 (FE3) 5-57
    Network settings 5
    14
    Touch [Forward ].
    Setup LDAP screen 6/6 appears.
    15
    16
    Touch [OK].
    17
    Touch [Close], and then touch [Close] in the next screen that appears.
    – To cancel changes to the settings, touch the menu item name in the Bookmark screen to return to
    The LDAP server is registered, and the authentication settings are specified.
Konica minolta c451 not booting after power on
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
Error code c-fe03 in konica minolta BIZHUB C-451 ?
MFP board issue might have a tech re flash the firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
I am facing p21 error in my bizhub c451 pls help me
p21 is stabilization failure. Try and clean the IDC sensors that sit below the transfer belt. also you can initialize and stabilize a few times in service mode as sometimes this can rectify a P21 issue. If all fails then it could be the actual ITB causing the issue
Ensure that the electrical connections both the plug in the wall and the connection at the back of the machine snug! Also good surge protector, on separate circuit? Then next is to have the machine software re-flashed. Must be from secure konicaminolta web site. Technician done
Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
