Condensor motot just replaced. AC unit was fine for 1st week. Now the air volume is little to none. Happens intermittenly, not all the time. Condensor is not tripping, I checked for that.
If air volume inside is dropping could be icing up or jsut a bad fan motor. Check to see if your indoor coil is clean. You have a goodman unit and they have a time delay relay for fan control. They go out quite often. If problem continues call aservice tech for free estimate. There is only so far you can go without knowledge of he system. russ
Testimonial: "Ok I was suspecting something like that. Will check it out thanks!"
