Question about Hoover Washing Machines
What does hO3 with.clock flashing mean on my hoover dynamic wizard wasing machine? Can't use the machine? Thanks in advance
6ya staff
SOURCE:
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: my Hoover wasing machine 800RL
hello ,
from what you described there could be a few things going on ..:
1..one of the rubber rings that balance the drum is either loose or broken ..
2 the bearing from the drive shift is defective ..
3 the counterweight is loose from the screws ..
4 the position on the horizontal plan is not perfectly
5 one of the screws ...is loose somewhere and is vibrating only on high speed spinning ..
But usually is either the suspension rubbers or the counterweight being loose
Posted on Mar 17, 2011
caroldon
  • 17130 Answers
SOURCE: how do you fix a motor jammed on a hoover wasing machine
Possible this can be the brushes or the bearings and you can get some tips from the links below:
motor bearings
motor brushes
Posted on Jul 03, 2012
dtcparkdene
dave cousins
  • 3 Answers
SOURCE: Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Posted on Sep 18, 2013
Anonymous
SOURCE: my hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
the door interlock has failed and needs too be replaced
you can find this easily changed out part on ebay or from spares suppliers
you usually need to take the top off the machine
power off and open the door and remove the two screws at the lock
reach down and take out the interlock mecha
plug in a new one and put it back and screw it back on
very easy...
Posted on Feb 09, 2015
Tom Chichester
  • 55370 Answers
SOURCE: Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
My hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
very easy...
Feb 08, 2015 | Hoover Washing Machines
How do you fix a motor jammed on a hoover wasing machine
motor bearings
motor brushes
Jul 02, 2012 | Hoover AAA140 Front Load Washer
Hoover error E08
Oct 02, 2009 | Washing Machines
Player does not read disc-code HO3
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Sep 29, 2009 | Panasonic DVD-LS90 Portable DVD Player
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing answer machine display
Flashing CL means that your clock is not set.
Jun 01, 2008 | Lands Phones
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
