Whirlpool dryer model LGR6611LQ0 will not heat up
Check for tripped breaker and proper voltage, next check to see if turns on if your getting air to the outside vent if ok the you need to open the unit up (unplug it FIRST) your be looking for the thermal fuse and or the cutoffs these will be attached to the blower housing assy ohm them out and also if electrical one check the heating element as well most cases this will solve your problems
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
