My toastmaster steamxtreme iron was left overnight plugged into the electrical outlet. I thought it had an auto-shut-off? Now it won't heat up. Any suggestions?
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary. God bless you
The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hi have a nice day!
Ensure that the unit is tightly plugged into a working outlet. Some units are equipped with our patented Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat.
Hi! Ensure that the unit is tightly plugged into a working outlet. Some units are equipped with our patented Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat.
