I just bought this and charged it for two hours and I couldn't get it to turn on so I put it in the charger again and the red light started blinking and it seems like it is not charging it just keeps blinking red. What should I do?
If you didn't pair your phone up yet, that could be why. Hold all 3 buttons down for 10 sec. should go solid blue, then pair your phone cause its in discovery.
This "solution" is useless! I had the same problem with 2 different units. Charging should take place when the unit is OFF. When it's off, it doesn't care whether or not it is paired, and should charge simply because the charger is connected. The flashing red light indicates a problem of some sort, although I can find no no explanation of it on the Internet, nor in the H710 user's manual.
It means you probably got it wet, they normally do not recover from this fault. I ruined two this way, found them in my paints pocket after washing them and all they did was blink afterward. The internal battery is ruined, just buy another :(
