Watches Logo
Posted on Aug 15, 2009
Hi I have a boys digital watch umbro brand and I can't set the time
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1724
Points
12
Press 'mode' (bottom left) three times until the seconds at the bottom of the display are flashing. Then use 'reset' (bottom right) until the part of the time you want to change is flashing. Then use start/stop (top right) to set the time. Use 'reset' to scroll through to the end.
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 • The Watches
4helpful
6helpful
Umbro u645u -Ive lost the manual & can't set anything please advise
Tap mode button 3 times then use reset button to move to part of time you wish to change. The st/stop button to increase digits. Hope this helps tez
Nov 24, 2010 • Watches
Umbro U333 watch. I need to know how to set time. I have no instruction manual. Please help.
Thanks for contacting FixYa.
You can find manuals and instructions at the following link:
www.bulovaspecialmarkets.com/service/servicecenter.aspx
Best regards. Jewel
How do I reset the time and stop the hourly bleep on a UMBRO U645U
Write down the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Sep 01, 2010 • Watches
3helpful
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Need to reset time
Just open your watch then look for negative and positive connection,then short it,for 3 seconds then it will reset all.
Hope it may help you;
Regards;
VOTIT
Apr 14, 2009 • Watches
2answers
Changing the time on an LCD Digital Watch
Malcolm S
Feb 29, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
