Yes, this is the way the flash can be used with the contemporary digital cameras. The camera has to be set to Full Manual mode (in point of the exposition), Exposure Time to 1/100 sec (or the shortest exposure that still assures full opening of the shutter). Aperture on the camera must suit the working aperture on the flash, also ISO speeds must match. The computer in the flash measures the reflected from the subject light and quenches the flash, creating the correct exposure. Mecamat sensor, having narrower reception angle and a sight, helps in achieving the correct illumination even on a relatively small subject. Sync voltage of Metz 45CL1 does not make harm to any digital camera, so you can use even the cheapest hotshoe-to-PC adapter available at many camera shops or you can buy one online. No need to spend much on sophisticated adapters.
If you are in Manual Mode and you set your shutter speed too higher (ie above 250th sec) the shutter blind passes over the sensor when the flash goes off causing a dark section in the photo. Lower the shutter speed to get a better sync. Some camera's default sync speed is 1/60th of a second and sometimes user adjustable.
Remember the longer the shutter speed, the more light will register in the photo. Also boosting the ISO will help extend the flashes range and also record more ambient light for a more pleasing and balanced photo.
Have you checked the flash mode?
I have no problems with the combination D300 SB-800.
I assume you don't have a picture if the flash goes off before the shutter open(?)
If you do check the menu e2 Flash shutter speed you can set it at a few seconds in spite of the fact that the flash sync (e1) is something reasonable like 1/250
The flash shutter speed is set to 1/60 in my camera...
it could be a shutter problem. however if it is only when using a flash it would be sync. for flash photography most cameras have a shutter speed that they sync at normally 1/60
On the D70 custom menu (Pencil icon), there is an option to Synchronise shutter speed below 1/60 second (the default).
See 21 Shutter spd.
You can select anything from 1/60th to 30".
