Why does the washer not change the cycle after wash and there is a click sound after the wash cycle and no rinse
    Sergeant:
  • 227 Answers
Your washer timer need replacing
Posted on Jun 24, 2019
6ya staff
SOURCE:
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: Washer quitting on rinse cycle
no cold water ,,lid switch or defective
Posted on Dec 25, 2008
James Chandler
  • 686 Answers
SOURCE: kenmore washer,mod# 110 26292694/wash cycle only
CHANGE THE LID SWITCH
Posted on Apr 09, 2009
Anonymous
  • 1185 Answers
SOURCE: washer won't drain after rinse cycle
If you lay the drain hose down into a bucket does water come out fairly quickly?
If so then it is not a blockage
You may have a coin or other small object in the pump which stops the impeller turning so no pumping action
Only solution is to check if the pump is free to turn either via the filter opening or taking the back panel off (Remove power before doing so ) and turning the pump by hand (there will be a fan blade on the end which is connected directly to the impeller.
If that will not turn very easily then you need to take off the hoses and check what is happening with the pump unit
Posted on May 23, 2009
Anonymous
  • 58 Answers
SOURCE: Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
Posted on May 29, 2009
the3car2004
  • 10 Answers
SOURCE: agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
Posted on Jun 14, 2009
Problem during wash cycle
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Mar 19, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
My washer does not drain after the rinse cycle
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
May 31, 2008 | Whirlpool Washing Machines
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Maytag keeps washing
Washer with O.C.D Darn, sounds like your timer sequence board has a problem. don't spose a warrantee issue?
Dec 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
