Computers & Internet Logo
Victoria Dusen Posted on Jun 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to get onto netflix via my tv but can no longer get on as it says Please check your network connection
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 26, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140443
Points
1832
Sounds like your TV is no longer connected to the internet. Check WiFi or Ethernet cable connections and try again.
5 Related Answers
Anonymous
  • Posted on Jan 04, 2009
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
Anonymous
  • 65 Answers
  • Posted on Apr 26, 2009
SOURCE: messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Anonymous
  • 767 Answers
  • Posted on Jan 14, 2010
SOURCE: "No signal" on hdtv while trying to watch netflix via xbox
First you need to eliminate the possibility that
the box is loosing video feed from the G.P.U.
hook the unit up in with normal yellow
white and red a/v connection for standard TV
out . if it happens shut the unit off and on again
and if you have sound and no video it's the G.P.U
becoming disconnect , the fix for this is to have
the chip re-flowed back to the P.C.board .the other
cause is a failing HDMI cable but im guessing you
already replaced that.
If you have any questions feel free to ask
Rob
Testimonial: "Very helpful"
Jobson143
Jobson.B. Jacob
  • 233 Answers
  • Posted on Nov 27, 2010
SOURCE: i have a sony bravia tv that can connect to the
yes by instaling pc suit
BElectric
DILLIGAF
  • 1140 Answers
  • Posted on Jan 08, 2011
SOURCE: My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
We have been using a Toshiba Blue Ray box for our netflix viewing. Two days ago it stopped were we can no longer get netflix via our blue ray or our WII. What's wrong?
This sounds like a problem either with your internet/network connection or Netflix. i would recommend a few steps to isolate where the problem is:
Step 1. Use another device, e.g. tablet, pc or laptop on the same network as your Blueray device/WII and see if you can connect to Netflix.
** If you cannot connect to Netflix, go to step 2.
** If you can connect, Netflix is fine, the issue is with the connection between your router/modem and the Bluray/WII console. Go to step 2.
Step 2. Take your laptop/ tablet and connect to another network, a friends or neighbors, or a hotspot from your phone. Then try to connect to Netflix.
** If you are able to connect and watch Netflix, the issue is with your network. Go to step 3
If you are unable to connect to Netflix, you may have a problem with your account. Contact Netflix support, who are normally very good at trouble shooting the problem.
Step 3.
** On the Bluray and Wii, disconnect from the network and forget this network.
** Next power off your modem and router, wait 10 minutes and power them back up again, modem first, then the router.
** Once all the right light are steady on both the modem and router, try to connect either the Bluray or Wii to the network and see if you can get Netflix to work. If yes, you are in luck! If no, you may need help from an internet professional or the 1-800 support line of your router manufacturer.
Hope that helps.
Connecting netflix
How do I set up my Panasonic TV?
Hit the Menu button on your Panasonic TV remote.
Select Network > Network Connection.
Select Wireless.
Select Wireless Network Settings.
Find your Shaw network name in the list of available networks and select it.
Enter your network password.
Your wireless connection should now be set up.
On these devices, the Netflix App can be accessed via VIERA Connect or the Netflix button on your remote control. If your Panasonic Smart Device does not have the Netflix App, it can be downloaded onto any internet connected external device (smartphone, tablet, gaming console).
What type of device do you have to connect to Netflix?
If watching in browser on desktop you need to install Silverlight
https://help.netflix.com/en/node/23742
Will this model of Panasonic Smart Tv play Netflix? I cannot find the Netflix app via Vieraconnect?
Hello friend...
For any help visit us: Netflix Com Activate
2helpful
2answers
How do I get Netflix on my tele I have sky and wifi?
What kind of t.v you have because some t.v don't have Netflix you have do download it or go bake to the you buy the tv and ask them
Oct 26, 2014 • Netflix
2helpful
Emerson lc320em2 how do we hook it up to netflix
The Emerson LC320EM2 is not a Smart TV. To display Netflix content, you can connect the TV to your computer via the VGA port on the TV. Then use the TV as your monitor; this may not work with HDCP content. To do this, turn off both the TV and the computer before connecting the devices. Then turn on the TV and set it to the VGA input (PC) before turning on the computer. (Note: you may have to enable the port in the BIOS on some laptops.) If your computer doesn't have a VGA port, try a DVI to VGA adapter. (This may not work with some video cards that only have digital signal output. Look at the port and make sure that the cable/adapter doesn't have more pins than the port.)
Alternatively, get a set top box with Netflix support. (Some Blu-ray players, the Roku box, Apple TV, or the WD Live Hub all have internet connection options and support Netflix. All will support a wired ethernet connection; some models will require a dongle to connect to a wifi network.)
Once you have the set top box, connect the TV to the box via a HDMI cable (purchased separately for most units). Connect to your internet connection and then log into Netflix, These steps will depend on the unit; please add a comment with your source of the Netflix content.
I hope this helps.
(I have an LG Smart TV; it is slow to find the wireless network when started. So expect some wait time before you can sign into Netflix.)
I can't connect to internet via my tv all the sudden . I streamed a movie on netflix just fine just yesterday . Today it won't connect . I checked allt he wires and connections to the computer and modem...
Here are a few things to try:
- Remove all the devices plugged into the netgear and leave only the TV and Internet connection
- Swap the cable for the TV Internet connection
- Try a different port on the netgear
- Monitor the activity lights on the netgear
Are you still able to connect to netfix via a computer?
Post any findings
11helpful
2answers
The Netflix app on my vizio svt422xvt (one of the Vizios with VIA internet & wifi built-in) won't connect to Netflix. It directs me to the Netflix website for help, but Netflix help tells me to...
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
