Question about GE Lands Phones
My ge 27958 will not playback msg.
Top 4 butto s on the phone does not work after power was off. Buttons are annku. Er, answerer, me o, play/stop. Everythi g else works. Msgs get recorded but wo t playback.
6ya staff
SOURCE:
Anonymous
  • 73 Answers
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Posted on Aug 02, 2007
Anonymous
  • 38 Answers
SOURCE: Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Posted on Aug 19, 2007
Anonymous
  • 169 Answers
SOURCE: My Touch Screen Buttons
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Posted on Sep 01, 2007
Anonymous
SOURCE: GE Telephone answering machine will not work
298976e2-a owners manual,
i have same problem,
sorry if my english not the best.
i "paste and copy"
We have the answering machine set to 4 rings. When people call, the machine picks up on the 4th ring, it beeps, then cuts off. No recorded message. No message is recorded, the call is disconnected. What do we do?
send me email.
samspicuglia@rogers.com>>>Canada
Posted on Jul 03, 2008
Anonymous
SOURCE: kxa144azt cordless phone answering machine problem
push int then# this is the menu for the answer machain um 00000 is the security code used to reset or reassign the hand pice
Posted on Mar 04, 2010
Answering machine model 27958 GE1- A records message but does not play the message. nothing happens when the memo button is depressed. how can I resolve?
Press the PLAY/STOP button to hear the messages. When you press the MEMO button, the system waits for you to leave a message.
If you need a manual, you may download a copy here. The message playback instructions are on page 33, the MEMO button is described on page 34.
Nov 09, 2012 | Lands Phones
I need replacement remote charger (part #5-2582) for my GE 2.4GHz speakerphone and answering system # 27958.
I love my old GE coded/cordless phone set, but the cordless phone's buttons won't dial anymore; they get stuck. Can I get a replacement for the cordless phone only? The charging cradle seems to still work. It is Model # 27958GE1 A. Thanks!
Dec 14, 2010 | Uniden Cordless Phone
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
Am tgrying To shut off the answering unit on the power Head.
There is a button on the base unit labeled answer on. Right next to is a light that indicates whether the answerer is on.
If what you are trying to do is stop the playback of messages, press the stop button. It has a square. If you want to resume playback, press the play button. It has a right pointing triangle. There are other buttons and they are also labeled like on a standard recording device for if you want to skip ahead orback.
Aug 11, 2010 | Panasonic KX-TG1033S Cordless Phone
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Nov 02, 2009 | Uniden Cordless Phone
Memory Full - model #27958 - GE 2.4GHz
if the play button on the base no longer works - on the handset just above the 3 is a silver answer/format button . . . press it for about 1.5 seconds and then press the 2
Sep 09, 2009 | GE 27928GE2 Cordless Phone
Dialing in to get Voice Messages.
After the answering machine beeps for you to leave a msg - enter the 3-digit security code. If you haven't already set that function up, the default is 1-2-3.
Once in, use these buttons for:
#1 - Review msg
#2 - Play back msg
#2 again to Stop the play back
or #0 to delete during play back
#3 - Skip
#4 - Turn off/on answer
#7 Review voice menu options
Mar 26, 2009 | Uniden Cordless Phone
Delete messages
This is from the manual.
Erasing Messages
You may erase messages in the following three ways:
To erase a message while it is playing
1. Press and release PLAY/STOP button.
2. Press the review and skip buttons to select and play the message you want to erase.
3. Press the delete button, the current message is erased, and the next message plays.
To erase all previously played Messages in a mailbox
1. Make sure the phone is OFF (not in talk mode)
2. Press and hold the delete button until "ALL OLD MESSAGES ERASED" is announced.
To erase a message from the handset :
1. Press the flash/answerer button on the handset
2. Press the play/stop (key 2) on the handset.
3. Press the erase (key 0) on the handset to erase a message during playback.
NOTE: Erased messages cannot be restored.
Jan 08, 2009 | GE 28112 Trio Cordless Phone
Lands Phones Logo
77 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
