SOURCE: kenwood dpx 4020
The iPod will stop itself from charging when the battery is full, and will not overcharge. I'm pretty sure you can't disconnect the power to the iPod (would stop it from charging) and still use the Audio to your stereo.
SOURCE: USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
SOURCE: Require a English User Manual for a Kenwood Car Audio
Visit HERE and enter the various model numbers and you'll get free manuals in pdf.
K
SOURCE: kenwood DPX 9000 MJ CDplayer
Start type the code on the face preset button only 1 to 4 to let it appear this number start from 3110 and press Play/Pause button. do itz until it's get to 3119.... the code is 3112 but it'z quite hard....
maybe ur rite!! solution num 2, put it in the trash!!!!
SOURCE: kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
