Question about Dewalt Drills
DeWalt charger is blinking fast - Dewalt Drills
    Top Expert:
  • Dewalt Master
  • 55,370 Answers
  • Defective battery
  • Defective charger
Posted on Jun 27, 2019
2 Suggested Answers
6ya staff
SOURCE:
agent91
Ned White
  • 2100 Answers
SOURCE: I purchased a new charger for my Dewalt Cordless Drill
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
Posted on Apr 25, 2010
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 | Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 | Drills
Dewalt DE0245 battery charger blink fast without battery inserted
It really sounds like the electronics in the charger are failing or failed, it's probably cheaper to buy a new charger
Mar 25, 2014 | Computers & Internet
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Two quick flashes problem powerline what does that mean exatly
From the manual.
Some chargers have a Problem Power Line indicator. When the charger is used with some
portable power sources such as generators or sources that convert DC to AC, the charger may
temporarily suspend operation, flashing the red light with two fast blinks followed by a
pause. This indicates the power source is out of limits.
Oct 13, 2013 | Dewalt 7.2-18.0 Volt One Hour Charger
I can,t charger my dewalt batteries , so is the fault with my charger
It is likely the fault is the battery and not the charger. To confirm this take the charger to any Radio Shack and ask them to test the charger or if you have a small meter do it yourself, the charging voltage will be up to 5 volts more than the rated battery voltage of the drill, so if you get a high reading don't worry about it. Fast charger will be way over the battery rating, also fast chargers have a cost, they shorten battery life due to heat. I have had many battery powered tools, I have found that the batteries last about 2 years on average. I have this same Dewalt drill driver.
Nov 02, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
I purchased a new DeWalt DW1916 Battery charger and when I install the battery for charging, the red light on the charger blinks on and off and after an hour the battery was still discarged.
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
Oct 01, 2010 | Garden
I HAVE A 36 VOLT DEWALT RECIP SAW, THE BATTERIES ARE NEW AND SO IS THE CHARGER. BUT THE CHARGER KEEPS BLINKING AS THOUGH THE BATTERIES ARE RUINED. CAN I RESET THE BATTERIES TO TEST
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
Feb 05, 2010 | Dewalt Drills
Drills Logo
70 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
