Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Kyocera Mita 3035 FileUtility disappears from the taskbar after a fax is received. what is the fix for this?
6ya staff
SOURCE:
Anonymous
  • 54 Answers
SOURCE: kyocera mita long distance faxing
Kelly,
I hate to point out the obvious, but make sure your phone line has long distance service, then make sure you are dialing 1 before the long distance number. You didn't mention if you had to dial 9 to get out. If you do, you may have to enter a pause between the 9 and the 1. What model Kyocera Mita do you have? The fax kits vary by model, and I can look up any issues with your particular fax kit given the extra info. Thanks.
Bryan
Don't forget to rate your answers please.
Posted on Dec 05, 2007
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: not getting faxes
Press the fax button....look in the tabs to set machine to auto-receive.
press ON HOOK and listen for the dial tone.
Posted on Jan 02, 2009
Anonymous
  • 3 Answers
SOURCE: our kyocera mita 3035 touch panel is not working.
Control panel problem
1-check connectors the input and if there is out put from the power supply board which is on right side of Main PCB and on the right side of fan
2-clean all the pcbs on Control panel,re seat connector
look for any piched wire/s
Posted on Oct 23, 2009
Phillip Fultz
  • 29 Answers
SOURCE: kyocera mita 3035 is offline cannt figure out how
If you are taking about the printer portion. Just hit the printer button on the left hand side. When the printer options pop up on the touch screen chose the option on the bottom right hand side (the GO key) of the touch screen that should bring it back online.
Hope this helps.
Posted on Aug 24, 2010
l_j_duplessi
Louis Du Plessis
  • 29 Answers
SOURCE: Kyocera 3035
if ti is a print from machine memory and not from glass the charge is durty the remove charge unit aboth drum and see if there is not durt on the charge wire or on the grid wires the green charge cleaner aboth the wast toner may also have come of and now staning on the rong place , if that is right your laser **** glass behide the drum may be durty if its a copy the small glass onther the document feeder is durty some copiers have a document feederthat have a scanner on the inside oppen the feeder lift the green lever and you fined a small glassin there that need cleaning and last o yes and last do this first open your left side door look at the drum if there a line on the same place than on the paper the drum blade does not clean it and a peace of paper may be stuck betweenblade and drum
Posted on Aug 07, 2012
WHITE LINE THRU PRINT ON KYOCERA MITA KM-3035
clean the LASER glass for that color, if you dont know what that is get a tech out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 22, 2016 | Kyocera Mita KM-3035 All-In-One Laser...
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Unable to change names/add addresses in the address book faxing
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Nov 03, 2017 | Kyocera Mita KM-3035 All-In-One Laser...
I need my scanner hookedup tomy pc on my mita 3035
You must have a Kyocera or Copystar technician set this up for you.
Jul 15, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Cannot receive faxes. Fax is set to auto receive and there is dial tone in machine. Any other ideas?
Call a cell phone from the machine and verify this is the correct fax phone number that shows up
You must be absolutely sure you have an ANALOG phone line. There is no other cure.
Kyocera fax systems are very picky.
Jun 04, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
Apr 03, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Not getting faxes
Nov 25, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
