SOURCE: How do i install java for the samsung galaxy tab
Even though Android is based on Java, you cannot just pop in a .jar file and play it. It needs to be in apk format, short for android package(i presume). You need to first transfer the file to your sd card and use a file manager to find it. then click + install. I suggest ASTRO (file manager)
SOURCE: My Samsung Galaxy Tab says
You're in download mode. If you're not connected to USB, then pull the battery and plug it back in. This will restart your device.
SOURCE: How do I delete all the applications and data on
Hey there,
In order ot hard reset your Samsung Galaxy Tab you need to perform the following steps:
Be aware that this will erase everything!
1. Turn the device off
2. while the device is turned off press and hold the volume up button and the power button
3. release the power button when you see the samsung logo appear. (Do not let go of the volume up button until you see the recovery screen)
4. use the volume button to naviagte through the menu until you find an option titled Wipe data / Factory reset
5. once you fin that option, highlight it and press the home button.
6. press the volume up button to continue
Your galaxy tab will now start the hard reset process, do not touch anything until it is complete
Hope this helps!!
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
SOURCE: How do I register my samsung galaxy tab?
http://www.samsung.com/us/support/account/regist
you will need to create a new samsung ID and then enter the serial number of your device to register it.
