Garden Logo
D
Daniel Dragovic Posted on Jun 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Husqvarna YTH22V46. Will not go fwd or rev when on the ground. When raised up it will go both directions, however, it can be stopped with the hand.
Wayne McNeil
Level 2:
Novelist:
  • Expert 209 Answers
  • Posted on Jun 30, 2019
Wayne McNeil
Expert
Level 2:
Novelist:
Answers
209
Questions
Helped
116606
Points
421
Sound like adjustment issues.
1 Related Answer
Eugene Rounds
  • 1169 Answers
  • Posted on Jun 14, 2015
SOURCE: Changed tire on Husqvarna yth22v46. Now it will not move fwd or in rev. The brake isnt working either. Engine turns on fine, free wheel lever can be pushed in, but it won't engage transmission
Most like the axle key is missing on the wheel you removed.
2answers
2015 Husqvarna 46 inch cu drove onto the trailer got it home pulled the neutral bypass and now it's stuck in neutral will not move in any direction
so is a
Husqvarna YTH22V46 22-HP V-twin Hydrostatic 46-in Riding Lawn Mower
this is real name, and is mower not a car.
moved yah
jack it up and wiggle rear tires to free up box ?
brakes set?
Mowing lower on right side than the left
Loosen the adjuster on one side of the deck and level off the deck and retighten. This should be done on top of a solid surface so u get it perfectly parallel to the ground.
Husqvarna YTH22V46 install clutch cable
Do you mean the electrical cable which feeds the clutch?
Need a starter for 3 phase motor with only two buttons, one for farward & another for reverse.button should be bell switch type, when presssed and hold, motor should run and should stop when released.
You will need a fwd-rev starter (has two contactors) You can buy any brand. You should have three buttons fwd stop rev
You could wire it so the fwd latches until stop is pressed, and the rev button momentairly so it stops when finger is removed.If you buy a brand with a general purpose (NEMA 1 ) enclosure you could put buttons in the cover, some even have buttons made for their covers.
Aug 11, 2010 • Garden
1helpful
760H projector will not go fwd or rev either from
The problem you are experiencing is caused by a broken cycle solenoid "link". The "link" connects the solenoid plunger to the slide change mechanism. Over time, the "link" (made of plastic) gets brittle, cracks and the projector stops cycling. Parts are still available (www.micro-tools.com), but this requires an experienced hand and a service manual. Once done, your projector should be good for another 20 years !!
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
