SOURCE: Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off. Try holding both volume buttons at the same time for a second or two. If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up. On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume. My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
SOURCE: Can't Hear anyone and they can't hear me
Be sure you have not muted the players. Also be sure that your system isn't set on mute.
To check, hit the middle xbox button on the controller. Go to settings, preferences, click VOICE. Be sure the mute box is not checked. Also be sure the volume is all the way up (max is 10), and the voice output is what you feel suits you.
Also, most headsets have a volume control on them (most of the time they are attached to the cord) and be sure that this is not all the way on low.
Hope this helps!
SOURCE: I can hear trough my headset but not talk
okay, this is obvious but first of all make sure this switch on your headset is not on mute. If alls good there go to your dashboard settings and you should see communication and make sure none of these are blocked. If this also isn't the problem it looks like you are going to need a new headset. It should have a years warrenty if that helps?
SOURCE: Turtle Beache X3 Headset Communication
You probably need a new talkback cable. They are purchasable on the turtle beach website or contact their support about a replacement.
SOURCE: i can't hear my friends but they can hear me on my xbox headset
It sounds like your headset is worn out. We are constantly replaceing them at my house. The little wires inside the cord where they go into the plug end tend to break and fail to give good/reliable conection.
You can try cleaning the plug end and checking that the receptical in the controler is free of debris, if that works great, if not buy a new headset.
Good luck
