Question about Kyocera Mita KM-5035 Printer
Kyocera mita 5035 scanner/reverse Jam 71 --- there is no paper but it will not clear the Jam 71 red light
5 Suggested Answers
6ya staff
SOURCE:
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Paper Jam in rear top
Yep! Top cover, left side cover, and both small rear covers must come off to remove the fuser. 4 screws and 2 plugs on the fuser.
Don't lose the spring on the rear swing-down cover.
Posted on Nov 16, 2008
n25an
Norman Davis
  • 622 Answers
SOURCE: How to clear paper jam at the back of Kyocera Mita
if paper is stuck in the back... then you have to take the machine apart... its messy but its just how it is... as for two sided printing... I would call kyocera support... they could best advize you on that... and they are quite friendly...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
shawn38
Shawn
  • 200 Answers
SOURCE: kyocera mita 5035 code 6400
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Posted on Jan 29, 2011
shawn38
Shawn
  • 200 Answers
SOURCE: I have a continous red light (paper jam) on a
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Posted on Mar 25, 2011
My kyosera mita 5035 it says tray its out of oder
This usually means that you have some torn paper jammed behind the cassette.remove the cassette and the torn paper.
Oct 05, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera 5035 scanner c7400
Image formation unit.
Has the drum been removed from this machine.Its either missing or requires replacing
Sep 19, 2013 | Kyocera Mita KM-5035 Printer
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera mita 5035 eror code c6000
i have kyocera mita this machine toch screen is working but numbers manual is not working please give me solution immediately
May 26, 2012 | Kyocera Mita KM-5035 Printer
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
Kyocera KM-5035 - I try to change the Developer Assy. I guess i have to make a reset in the service mode or something but i dont have the code. Can someone help me? Thanks!
After replacing developer unit
press
10871087
scroll up to u130
press print button
let machine run till it stops.
clear
u001
press print button
READY
Jul 10, 2009 | Kyocera Mita KM-5035 Printer
Copies are very light
check your transfer roller when removing the jam you broke the holder on the transfer roller and the contact spring fell out, no repair has to be replaced
Mar 26, 2009 | Kyocera Mita KM-5035 Printer
0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Mar 13, 2009 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-5035 Printer Logo
20 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
