Question about Toshiba Televison & Video
Toshiba tv has no audio output, input only...i need output to hook up my tv hearing devive what do i need to do
    Top Expert:
  • Toshiba Master
  • 55,370 Answers
Replace the TV with one that has audio output.
Posted on Jun 30, 2019
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
tvtek
Duke
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
Anonymous
  • 306 Answers
SOURCE: HDMI to DVI gives pink screen
Make sure the Geforce outputs in DVI-digital
then  Boot the PC while the TV is on and connected. This allows the card to read the EDID from the TV and provide the best resolution...
Most displays work best at their native resolution, which is either 1920 x 1080, 1280 x 720, or 1024 x 768 for most HD TVs. It sounds like your video card has difficulty handling resolutions that high and that may be your problem.
One has to remember that DVI/HDMI is capable of carrying two types of Colourspaces: RGB and YPrPb. Unless modified, the PC will always output RGB.
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem,  Make sure the Geforce outputs in DVI-digital
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem, as well as contact toshiba if swapping the cable and box doesn't resolve the color problem.
Posted on Oct 17, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Posted on Jan 17, 2009
Anonymous
SOURCE: Hooking up TV Guardian with Samsung HT-SK5
Just purchased system, didn't come with any speakers, but when hooked up to tv get picture and no sound unless I put headphones in.
Posted on Jun 05, 2009
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
I want to hook up a Toshiba laptop to a Panosonic rear projection
VGA, and supervideo only carry the visual signal, so if you use one of this cables, (both the computer and the tv have to have the same output/input) then you have to have a cable attached to the computers audio output to carry audio to the TV. If your computer has HDMI output and the tv has an HDMI input, then that carries both visual and audio. When you attach the video cable to the tv, put the tv on that input source and the computer will sense the device and if the drivers are updated will fire the signal up automatically and give you the choice of using only the tv, or using both the tv and laptop monitor.
Sep 27, 2009 | Computers & Internet
No owner manual. How to hook up stereo cable.
there will be on the back of the tv two "audio output" jacks( L & R ),one red one white. those two connected to the "audio input" on the stereo will give you the tv sound
Mar 14, 2009 | Toshiba 32A50 32" TV
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
Jul 29, 2007 | Pioneer VSX-406 Receiver
No sound on my toshiba television
just be basic....dvd is ouput goto tv input...watch the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
