Televison & Video Logo
A
Anonymous Posted on Jun 30, 2019
Remote control lg lf-k5931 - LG Televison & Video
john h
Level 3:
Top Expert:
  • LG Master 29,494 Answers
  • Posted on Jun 30, 2019
john h
LG Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7560467
Points
193449
My windows on my 2005 F150 FX4 will only operate from the drivers door switches. New switch panel on the drivers door.
What's FX4 ? How many door's ? Do the other door switches have battery power ? Can you test this with a volt meter ?
Principles of Operation
The left front window switch may be used to raise or lower all windows, or each individual side window may be controlled by the control switch located on each door panel.
The instrument control module (ICM) controls power to the power window system by activating or deactivating the delayed accessory relay.
The one-touch down feature will completely lower the driver side window when the master control is fully depressed, then released. The one-touch down feature is integrated into the LF window control switch.
There are 2 modes of LF window down operation: manual mode and auto mode. The manual mode is selected by pressing the LF window control switch to the 1st (DOWN) position. In manual mode, the window will move downward only while the switch is depressed. When the LF window control switch is pressed to the 2nd DOWN position, it enters auto mode and the window will open completely with a momentary press of the switch.
When the one-touch down feature has been activated, it will stay on until one of the following conditions is met:
  • The LF window control switch is pushed to the UP position.
  • The LF window control switch is released (OFF position) and then moved to the DOWN position (1st detent) or ONE-TOUCH DOWN (OTD) position (2nd detent).
  • 7 seconds have elapsed since OTD was initiated.
Window operation is enabled whenever the delayed accessory is active and the LF window control switch is pressed to the UP or DOWN position. The switch provides delayed accessory power to one side of the motor and ground to the other side. The one-touch down feature is not active when the LF window control switch is in the UP position.
Passenger windows may be raised or lowered using the LF window control switch or the appropriate passenger window control switch. Passenger window control switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The delayed accessory relay provides power for the operation of the power windows and the power roof opening panel. The delayed accessory relay is active whenever the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The ICM will deactivate the delayed accessory feature when:
  • The LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • The RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
  • Symptom Chart Condition Possible Sources Action
    • All power windows are inoperative
    • Fuse(s).
    • Circuitry.
    • Instrument cluster module (ICM).
    • Accessory delay relay.
    • Driver window control switch.
    • Go To Pinpoint Test A .
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
I am trying to set up my LG Magic Remote to work with a Openbox V8S, but openbox is not listed? Does anyone know how to do it?
Magic Remote Control - LG Smart TV: Online User Guide
eguide.lgappstv.com/manual/gb/12018.html
Your LG Smart TV includes a Magic Remote Control that acts as both a cursor ... Toconfigure the speed, shape, and size of the Magic Remote Control pointer, ...Missing: openbox ‎v8s
[PDF]Magic Remote - LG.com
www.lg.com/us/.../AN-MR500%20owner%20manual.pdf
LG Electronicswww.lg.com. Please read this manual carefully before using your remote and ... Magic Remote and Alkaline Batteries (AA) ... Press the up, down, left or right button to scroll.... The Magic Remote may not work properly if a wireless router (AP) is.
LG ANMR500 Magic Remote Control LG Universal ... - eBaywww.ebay.co.uk > ... > Remote ControlseBayLG ANMR500 Magic Remote Control LG Universal Remote - Richer Sounds in ...We've tried to explain some of the more exotic functions and facilities you might ... us with are incorrect or if any order is held up as a result of incorrect details. ... Returns • Goods, other than faulty goods, may be returned within 7 working days ...New Genuine Remote Control Magic Smart TV's LG AN ...www.ebay.co.uk > ... > Remote ControlseBay
1helpful
Wat is the code for LG TV
LG 044,005,009,056,057,155,156,172
Here you will find various remote control code for the LG TV.
Comcast Universal Remote Custom 3-Device . LG 0056
GE Universal Remote Control code LG . 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Philips Universal Remote Control code LG. 0002 0606 0502 0102 0324 0435 0802 0307 0609 0217
RCA Universal Remote Control code LG.1005 1082
Innovage Jumbo Universal Remote Control code LG. 004 005 009 056 057 155 156 172
Looking for manual fo an lf-irx
You can find the manual for the LF-IRX Remote Control Extender by clicking here.
If you don’t have Acrobat Reader to open the downloaded pdf manual you can download the Acrobat Reader by clicking here.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
2answers
What does this key do?
LF means line feed. This was a common key on typewriters. Now we just use the "Enter" or "Return" key.
Return meant the return of the carriage (the part on the typewriter that holds the paper and moves side to side as you type).
Basically, this just starts a new line for your text.
You can see this by typing a text message then add the LF and keep typing.
You can see the above text by scrolling with your finger.
10helpful
2answers
Bravo 13 in 1 tv remote control
Greetings and blessings,
I am trying to use the Bravo 13 in 1 remote control on Toshiba tv to set up my BT Vision. I cannot do this because I do not hav ethe manual for the Bravo to enter the code.
Can you Hlep me please?
Thank you.
Chris
Blessings
LFD 7150, echo stuck on
http://www.retrevo.com/s/LG-LF-D7150-review-manual/id/366ag218/t/1-2/
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
