Nancy Vacc Posted on Jun 30, 2019
How do i change the language on an itouch air
Roy Cunningham
Level 1:
  • Contributor 35 Answers
  • Posted on Jun 30, 2019
Roy Cunningham
Contributor
Level 1:
Answers
35
Questions
0
Helped
15757
Points
87
Reset to factory settings
If your screen is dim, touch the screen to wake up the watch.
Swipe down from the top of the screen and tap Settings . If you don't see Settings, you're using a different watch version. ...
Tap System.
Scroll down and tap Disconnect & reset.
When asked to confirm, tap Done .
Change the language on an itouch air 3
To change the language on an iPod Touch Air 3, follow these steps:
  1. Go to the home screen of your iPod Touch Air 3.
  2. Tap on the "Settings" icon.
  3. Scroll down and tap on "General".
  4. Tap on "Language & Region".
  5. Tap on "iPhone Language" (or "iPad Language", depending on your device).
  6. Select the language you want to use from the list of available options.
  7. Confirm your choice by tapping "Done" in the upper right corner.
Your iPod Touch Air 3 will now use the selected language.
2answers
How do u connect iTouch air to wifi
Download the itouch Smart Watch app from the app store or Google Play and pair your phone to the iTouch air using Bluetooth
1helpful
How do i change lanuages on my itouch air
  1. Open Settings. On the Home screen, tap Settings.
  2. Tap General. On the next screen, tap General.
  3. Select Language & Region. Scroll down and tap Language & Region.
  4. Tap Device language. On the next screen, tap "[Device] Language".
  5. Select your language. Pick your language from the list. ...
  6. Confirm your selection.
Itouch home button does not work after screen change
did U change the screen? or did u take it somewhere?
it might be because contacts don't line up together well
u can try to push charger up to get better contact or open itouch and fix button using video on youtube
Itouch player not responding
Have you tried resetting the iTouch? How to reset Apple iTouch Apple also has an Express Lane Support with more help options for your device; just enter your serial number. Express Lane Apple Support You might have to backup you iTouch Music in iTunes and reset your device to factory settings. But first try the soft and hard reset before restoring the iTouch to factory. More reset resources And furthermore: Apple's instruction site for restoring the iTouch
I cannot send e-mail but I can get e-mails on my iTouch.
Try changing the Outgoing mail to "smtpauth.aol.com"
How do I change my itouch to English?
Go to Settings. First there's Wi-Fi, ignore that. Then there's Screen Brightness, ignore that. Then there's General, tap on that. Scroll to the bottom. At the very bottom there's Restore, ignore it. Above it there's International, tap it. Tap the first option (Language). Then choose English! Hope that I helped!
Dell cordless keyboard keys deliver wrong alphabet
Follow these steps to make sure your keyboard is in the right language settings
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
If a language does not appear in the Input language list, the fonts for that language might not be installed. If that is the case, follow the instructions below.
  3. Open Regional and Language Options in Control Panel.
  5. Under Supplemental language support, select the check box beside the applicable language collection
  6. Click OK or Apply. You will prompted to insert the Windows CD-ROM or point to a network location where the files are located. After the files are installed, you must restart your computer.
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
