Question about Electrical Supplies
How to replace an oil seal in a tiger generator
    Master:
  • Electrical S... Master
  • 265 Answers
We have a whole Help Center dedicated to helping people fix their Portable Generators. Check it out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
How to replace an oil seal in a tiger generator - image-2fwsrbehqcya13uxwt41l5dc-1-0_4.jpg
Posted on Aug 19, 2019
    Top Expert:
  • 10,535 Answers
Your message does not qualify as a question or query for a problem, try somewhere else
Your message qualifies as SPAM
Posted on Aug 17, 2019
    Sergeant:
  • Electrical S... Expert
  • 290 Answers
How long did it take for oil to leak? First, oil seal material selection, second, oil seal selection. Third, the external environment (whether impurities enter). When changing, wipe around, grease, don't scratch the seal lip, etc.
t is recommended that you reflect the above situation to the supplier, so that they can solve the problem, do not make their own replacement.
If you are interested in other brand diesel generator set, such as Cummins, Volvo, Perkins, Deutz etc, please visit at:
https://www.dieselgeneratortech.com/diesel-generator
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: oil leaking from generator
Whose engine do you have? Briggs and Honda have websites where you can down load their manuals and replace the rear seal.
Posted on Jan 04, 2009
If the motor was ever filled with oil, will that blow a seal or gasket and cause it to leak out of engine.
if the motor was overfilled it would blow a seal on oil look at the to main seals being bad should be under warranty
Sep 12, 2014 | Electrical Supplies
Oil leaks from the bottom of the generator. Where could it come from?
bottom of generator would have a small door fastened by two screws tighten the screws to reseal.other gasket known as the front crankcase cover gasket may also leak from underneath check rear shaft seal if front shaft seal is not leaking.
Aug 09, 2014 | Briggs 5000/6200watt stratton Generator...
I have a oil leak on a coleman generator
Most likely at the output shaft of the motor. If you are handy, you might be able to replace the crankshaft seal yourself, but this will probably require you to seperate the generator from the motor, and remove the cover holding the seal. If the leak is small, it may be best to just keep adding oil. If you have to take it to be repaired, it may be more expensive than the unit is worth.
Mar 26, 2014 | Coleman Powermate Powermate 5000W...
My coleman powermate5500 mod 0525500.01 leaks oil between motor and gen. how to fix
The crank shaft seal is bad on the motor. You will need to seperate the motor from the generator to replace the seal. Depending on the seal design, you will have to open the crankcase on the output shaft side to remove the seal.
Mar 25, 2014 | Electrical Supplies
Ive a GT5250- WK PowerBack generator and it's leaking oil from I don't know where. Can you help?
usually its the seal were the geny joins the engine u will need to separate generator from engine check the seal and replace with new one,
Oct 11, 2013 | Groove Tubes Power Back 5,250-Watt...
I've noticed oil leaking from the unit but don't know where its coming from.
check at joint between engine and gen, its usually the engine oil seal need replacing u will need to split engine from gen, and replace the oil seal
How to chanGe oil seal in generator
I have 2kva generator, i want to change the oil seal, so how can i dismentle the generator, pl guide me step by step
Apr 10, 2012 | Electrical Supplies
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Oil leaking from generator
Dec 15, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
