Question about GE Washing Machines
Washer won't spin fast - just churns slowly back and forth
GE frontload, WSSH300GWW
    Top Expert:
  • GE Master
  • 10,627 Answers
Possible worn belt or bad motor
Posted on Sep 28, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Posted on Apr 13, 2008
Anonymous
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
Anonymous
  • 21 Answers
SOURCE: GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at thadoggma420@hotmail.com
Posted on Jan 22, 2009
Lloyd
  • 89 Answers
SOURCE: Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
Posted on May 20, 2009
Anonymous
  • 28 Answers
SOURCE: My Ge wssh300gww will
As the other posters mentioned, the problem with draining is most likely caused by a clogged filter. Mine had 14 cents, 2 zip ties, and a bra wire stuck in it. Here is the process (after many hours of swearing and bleeding) so that it should be pretty easy.
The first step is to tilt the washer back so the front is 3-5 inches off the ground. Prop it up with something. To remove the front lower panel, there is 2 phillips screws under the bottom edge. Remove the screws and the panel should drop down off the pegs holding the top edge in.
Inside, attached to the drum you will see a rubber boot with an accordion sleeve which contains the filter. There is 2 green spring hose clamps (the source of many expletives) and a silver phillips screw on hose clamp. To get at the filter, you should not need to, nor do you want to, remove the green spring clamps. You will spend hours trying to get them back on.
I have attached a picture for reference. Unscrew the silver clamp (large one, closest to drum) and pull down the sleeve to get access to the filter. If you are full of water, you can slide a pan inside the machine and just pull down the edge closest to the pan to drain until the water is gone. Reach down into the accordion (gross) and grab the filter. It has a lip on it so you will need to work it out through the accordion thing, but it likely has some really gross stuff in it. Clean it out, wad it back into the boot, and reattach to the drum. Dump about 2 gallons of water into your drum to make sure you are not leaking. Switch the knob to spin cycle and hit start 2 times. It should drain the water out within a couple seconds.
Posted on Sep 06, 2009
I TOOK THE 2 SCREWS OFF OF THE DOOR LOCK, THINKING I WAS REMOVING THE FRONT PANEL OF MY GE WSSH300GWW
First unplug the machine. If you remove the bottom panel you can reach all the way to the door lock position and should be able to reattach it easily. Why if i may ask were you trying to remove the panel?
Jan 27, 2013 | General Electric WSSH300GWW 3.5 Cu. Ft....
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
Machine is stuck on fast spin.
First Start your machine with a low spin and slowly slowly increase the speed until it becomes fast I hope it helped : )
Aug 25, 2010 | GE WBSR3140DW Top Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Jan 22, 2009 | General Electric WSSH300G Front Load...
Washer does not spin out water
I am assuming this is a front loader. If so, watch it go thru the cycles. Does it do a fast spin at any time? If yes, it's likely the belt is slipping. If it only goes back and forth slowly, you have another problem with the electrical control... the same as mine and I'm still trying to get to the bottom of it.
Apr 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
156 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
