If you have an antenna, you are trying to receive off-the-air broadcasting. Remember that a couple of years ago the US switched to digital broadcasting and analog stations went off the air. Your TV does not have a digital tuner, so you need an digital-to-analog adapter if you want to receive anything.
The US government had a program before the switch to help pay for the adapters, but that's long past now.
Radio Shack sells them as do other retailers, and you can find them online as well.
The adapter picks up the digital broadcasts and converts them to a channel 3 or 4 TV signal that the analog tuner in your TV can receive. Some models of converter also feature video and audio jacks so you can connect it as an AV source like a DVD player. Once you've hooked the antenna to the converter and the converter to the TV, you'll be able to watch your local channels again. Maybe, that is.
The trouble with digital broadcasting is that signal strength makes a huge difference in reception. With analog, a weak signal would still give you a fuzzy but watchable picture. A weak digital signal may not even be detected, or you might get a picture that breaks up (pixelation) or freezes on the screen. You don't say what kind of antenna you have, but unless you're in or very close to a large city or near the station's transmitter, simple rabbit-ears may not be enough. Many people found after getting an adapter that they needed a better antenna, even something on the roof. In some areas (valleys, remote areas, places surrounded by many tall buildings, for instance) people found they could never get any channels. If you do in fact have a digital converter already (you didn't mention one), this could be the reason you can't get anything.
Hope this helps you figure out what's wrong. Thanks for using Fixya!
My TV is connected to a digital box that receives it's signal over cable.
