What is the procedure to access the drum rollers on a Maytag Neptune front loading dryer ?
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Look at the front of the dryer. About 3 inches from the bottom of the dryer on the far left and far right are two philips head screws. Look real close as they are hidden. Take they screws out then the bottom pulls out towards you and the top slides down. After you get that off, taking the rest of the dryer apart is easy. NOTE: When taking the belt off note the postion and at which way the belt is sitting on the drum, also note how it goes around the pulley as you will catch heck putting it back toghter if you dont... GOODLUCK:)
changing the drum bearings in maytag bravos xl gas dryer
