Question about Dell Latitude D800 Notebook
Dell latitude D520 will not start up
When I res power button, on light comes on. hard drive light comes on then goes off. number lock illuminates. caplock and keyboardlock flash. 20 seconds later with a small squeak all off.
I have tried in docking station and out, and with different power lead.
  • 32 Answers
The board not holding power,
this can be first chk the RAM press it tight.
the next is chk smps output.
Posted on Aug 17, 2009
Testimonial: "Spot on. took out RAM, reseated it. works fine. well done, hole in one."
  • aamir_zia24 Nov 04, 2010
    There are 2 RAM modules (Internal and external). Which RAM module should be checked?
    New Friend:
My dell latitude d520 will not start. i have power but the lock symble with the a and the one with the down arrow blink and the lock with a 9 stays on but nothng else happens any ideas?
Posted on Jun 19, 2010
6ya staff
SOURCE:
Logitech MK300 Keyboard Ido not know when CAPS are on or off
there should be three lights just to the upper right of the keyboard. experiment abit with your caplock key and watch the lights. Caplocks on for my particular keyboard is the center light as it seems to be on must keyboards.
Jun 22, 2011 | Computers & Internet
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Dimension 8400 will not boot and more.......
I would recommend testing the power supply as Dell PS's are not known to be "forever". A power supply tester can be purchased online at Tigerdirect.com for around $20 and they are fairly easy to use (you can also get a new PS there if necessary). If that is not it, I recommend going to a local small computer shop and picking up a used Hard Drive (be sure to get SATA), and switch it for your main HDD,, if the PC starts up and goes to an "Error no OS found" or the ilk, the culprit is your hard drive. I am in CT and fix PC's for a living, I am A+ certified and have passed all the dell Factory Cert tests. If you need help and are in the area or work well over the phone,, let me know I CAN solve this problem.
Jim
Aug 04, 2009 | Computers & Internet
Maintenance light flashing
h) Engine Oil Replacement Reminder
Light (for vehicles sold in U.S.A.)
This light reminds you when to replace
the engine oil.
This light will come on when the ignition
key is turned to “ON” and will go off after
about a few seconds.
When you drive for about 8000 km (5000
miles) after the engine oil replacement,
this light illuminates for about 3 seconds
and then flashes for about 12 seconds
with the ignition key turned to “ON” position.
If you continue driving without the
engine oil replacement, and if the driving
range exceeds 12000 km (7500 miles), the
light will come on after the ignition key is
turned to “ON” position. The light will remain
on thereafter.
If the light is flashing, we recommend that
you replace the engine oil at an early
opportunity depending on the driving and
road condition. If the light comes on, replace
it as soon as possible.
You need to reset the light after the engine
oil replacement. Reset the light by
following the procedure below:
1. Turn the ignition key to the “OFF” position
with the odometer reading shown.
(For details, see “Odometer and two
trip meters” on page 136 in this Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset button.
Hold down the button until the light goes
off. Before the light goes off, it illuminates
for 3 seconds, flashes for 2 seconds and
illuminates for 1 second.
If the system fails to reset, the light will
remain flashing.
I copied this from page 143 of the owners manual for the 2004 4Runner
Jun 04, 2009 | 2004 Toyota 4Runner
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
LaCie 250Gb drive does not power up
It's the power supply connection in the HD case has failed. Try the HD in another case (if you have one handy) to check whether this is the problem. If so, find a replacement case.
Apr 30, 2008 | LaCie (300728U) 250 GB Hard Drive
My xbox no show no picture
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
Check here for more things to try
Oct 30, 2007 | Microsoft Xbox 360 Console
Dell Latitude D800 Notebook Logo
1,785 people viewed this question
Ekse
Clive
Clive
Alun Cox
