Question about Nokia Computers & Internet
Hello sir, I want you to help me if it is possible, Help me to unlock the RESTRICTED CODE OF NOKIA CE0434, MODEL: CE-02, TYPE:RM-692, CODE:059J662 and IMEI: 359292/04/187647/5. Thank you too.
I shall be very grateful to your good answer.
6ya staff
SOURCE:
Anonymous
SOURCE: Restricted code require for Nokia 6300
hi all, I have a nokia 6300 which brought back from indonesia and need the unlock code as well. phone model : nokia 6300, type : RM-217 IMEI #359544018940944. Thanks
Posted on Nov 21, 2008
Anonymous
  • 34 Answers
SOURCE: nokia 2630 security code unlock
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
Posted on Jan 02, 2009
Anonymous
  • 135 Answers
SOURCE: undo restriction code nokia 6500s-1
NOKIA UNLOCK AND OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
Posted on Feb 21, 2009
Anonymous
SOURCE: Nokia 6500s1 Unlock Security code
can not switch on the bluetooth on my 6500s-1
Posted on Sep 13, 2009
browneyes64
SOURCE: nokia5000
puk code
Posted on Jan 06, 2010
Unlock code
You can get the unlock code for Nokia X2-01 from SimpleUnlocking.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
May 12, 2013 | Nokia 002T9B4 X2-01.1-rd GSM Includes...
I need the unlock code for nokia C2-02
Visit the site Onlinegsmunlock.com/nokia/rs7wp8/ get the unlock code and unlock it easily.
Jun 26, 2012 | Cell Phones
Lupa kode pengaman
please help send me the code to unlock my Nokia 1280 type RM-647
model : 1280 type RM-647 nokia : korporation CODE : 0593073 IMEI : 357001/04/914904/7
Feb 14, 2012 | Nokia 1280 Cell Phone
Hi can't unlock my mobile phn. My phn is a Nokia CE0434,z276,model 6500c, Type RM-265
Have you tried before to unlock your mobile? if so how many times have you tried? because unlocking by codes is restricted to some extent for every mobile..for unlocking code you can try either from your provider or can try from online providers..try mobileunlocksolutions to get unlock code for your mobile and before unlocking try to know the complete procedure about how to unlock your mobile..just try mobileunlockguide to get step by step instructions about unlocking your mobile..
Jun 20, 2011 | Cell Phones
I forget my security code of nokia ce0434
You may try default phone and security code to remove
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Sep 07, 2010 | Nokia 1650 Cell Phone
5000d-2 unlock security code
MY MOBILE NOKIA 5000d-2 this mobile number lock activetd
but this mobile password code missing
serial no:324838029646143.
Type:RM-362
Code:0568255
imei no:354838/02/964614/3 PLEASE HELP SUPORTING PASSWORD
Sep 30, 2009 | Nokia 5000 Cellular Phone
Phone restricted
Try this code. I have a Nokia Master Code calculator, it shows me the unlocked code for when you lock your phone and forgot the code, but give it a try, who knows. 1066541060 I hope it works.
Sep 20, 2009 | Nokia 6300 Cellular Phone
I forgot my security code of nokia 1650
how to breck security code of nokia 1650
Jun 23, 2009 | Nokia 1600 Cellular Phone
Nokia 6085h, CE0434
hi
sir if your mobile is locked and you dont know the code then make it format by doing this. First of all turn off your mobile then hold the following keys:
1) * star key
2) 3 key
3) green key ( anserring key)
and then turn on your mobile dont leave the keys until you didnot see the hands animations when the hand animation apears leave the keys the mobile will be formated automaticaly
thanks
your friend from fixya!
Oct 28, 2008 | Nokia N73 Cellular Phone
i have nokia nokia 6300 vietnam need the unlock code phone restricted
1.phone model : nokia 6300 , (type ; RM-217)
2.imei # 354189029721746
3.the network where you pjone is locked to : vietnam
Oct 08, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
