Both roller tracks that hold the dual crispers on our fridge are broken probably too much weight on the glass shelf and in the crispers. The broken tracks are 17" long and held up with a screw into the side of the wall of the fridge. The fridge is white. The model # of the fridge is KBRS22JFWHO The MFG# is P1308901WW The Serial # is ECG2702863 Both the left AND the right sides are broken. If I knew the part #'s They might be available somewhere or perhaps you have them. Thank you.
Ken Sello
SOURCE: i need new parts for
www.partstoday.com they will need the model number to be able tro search for the parts, enjoy.
SOURCE: whirpool et21pkxgw03 refrigerator
This is a common problem when the defrost condensate drain becomes blocked. Depending on the location of the blockage is the clue to how to prevent the blockage. Most times the blockage begins inside the freezer and overflows into the freezer creating a huge area of ice while at other times the blockage is just as it leaves the freezer and makes its turns going down to the pan below your refrigerator to reevaporate into the air inside your home. On the link below the whole page shows way of this happening and ways to stop it and resolve the problem. Read the entire page and use the part that most refers to you leaking problem. If you have further questions please contact me at [email protected], Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
SOURCE: chemical smell in freezer and refrigerator
Have you tried cleaning wil Bon Ami ? Sometimes , we have to clean our reconditioned appliances that we sull to environmentalists ( detergent smells , fafric softner smells , etc , ) . Refrigerants ( freon ) have no odor , so it has to be the inside plastic which has the odor . Try Bon Ami and if that doesn't work , stuff 1 freezer shelf with crumpled up newspaper . The ink in newspaper , absorbes odors . This is the only way to remove fish odor in freezers that have quit cooling .
SOURCE: broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
SOURCE: puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
