Question about Frigidaire Refrigerators
HOW DO YOU FIX THE HI CODE ON A FRIGIDAIRE SIDE BY SIDE
My side by side frigidaire was giving me a H1 code so i unplugged it for 3 days and as soon as i plugged it back in it gave me the H1 code. How do i fix this problem?
HI error means unit has detected temps are too high in either fridge or freezer. Since you’ve already unplugged it and code came back, you’ll have to determine what’s causing the temperature problems
Oct 05, 2018 | Frigidaire Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Oct 13, 2012 | Frigidaire FSC23F7DSB Stainless Steel Side...
The water wont drain. I need help. the manual? or give me the instruction how to fix it problem. Model nbr is LTF2140ES2. 115 VAC-60HS-8AMPS
Number one problem with front loads are the clogging of the pumps, but you should get a fault code with the unit at the same time. In order to fix this you will need to remove the front panel below the door, there is a large black hose located inside on the right hand side with 3 clamps on it, remove that hose and clean out the coin collector. If full of water, it holds about 6 gallons, so be-careful to get out as much water as possible before remove this black hose.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 15, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
May 17, 2010 | Frigidaire FES367 Electric Kitchen Range
Can I fix the broken ice arm on the door of my frigidaire? Where do I get the parts?
Hi, if its still on warranty, you can have it fixed or still contact the service centre of the brand manufacturers usually its through authorized distributors.
thanks
Apr 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side error code 4
I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
Thanks, Anibal
Oct 30, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Refrigerators Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
