Question about Westinghouse Televison & Video
Run auto scan for cable on westinghouse television
My cable guy told me to run autoscan to regain lost channels. I can highlight INPUT to get TUNER, but it won't let me do anything else.
6ya staff
SOURCE:
freetek
Steve Allison
  • 5569 Answers
SOURCE: Channel Scan
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Posted on Nov 28, 2008
Anonymous
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
nadigrao
Avinash Nadig
  • 8 Answers
SOURCE: Philips SAA7130 TV tuner not scanning channels
hi try this procedure
1.go to device manager
2.then double click sound,video and game controller
3.then right click on saa7130 tv card (which is the driver u should have installed earlier)
4.then right click on that and select update driver software
5.the option box appears select browse for driver software on my computer
6.next u get two option select second one i.e let me pick from a list of device drivers
7.then u fine two collumed table manufacturer and modle.(note:uncheck show compatible hardware)
8.then under manufacturer select philips semiconductors then from model select saa7162 ,hybrid capture device and install.
8 it may warn about windows signature..some thing like that but dont worry just continue
9.it installs the driver.
10.then restart your pc
11.on windows startup it may show error like no device some thing like that .u just run ur tv application
if it works the dont forget to tell thanks
if it dosnt the sorry for wasting ur time
Posted on Jun 17, 2009
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
Posted on Sep 04, 2009
Bob Entis
  • 14 Answers
SOURCE: My cable input has disappeared.
- Press Menu
- Press 991
- Go down to Memory recall and press enter
- It will ask you "ARE YOU SURE"?
- Select "Yes" and press enter
- It will take you back the menu screen, turn off the TV and turn it back on user_offline.gif quote.gif
Posted on Jul 26, 2010
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
Westinghouse VR-2188 will not find channels when hooked up to comcast basic cable box but will if connected straight into wall, whats wrong? Cable box works on all other TV's in the house also so it is...
Make sure you have selected "cable" as the source input to the tuner. If there is a selection for both digital and analog channels when doing a channel scan then select it.
Jan 04, 2014 | Westinghouse Televison & Video
How do I run channel auto scan
Press MENU, use left/right buttons to get to input, then select AUTOSCAN using up/down keys and SELECT/ENTER button. This will take a while, 3-5 minutes. When it finishes, it will default to channel 2. At t.his point, push LIST button to see all stations it found.UP/DOWN buttons will let you select station of interest.
Dec 20, 2013 | ViewSonic N1630W 16 in. LCD TV
Have a curtis tv , trying to run autoscan, it runs, but it doesn't locate any channels. I have a comcast converter box also. Not sure why autoscan isn't working. Or do I have to set up my comcast...
For the auto scan to detect there must be channels present on the CABLE that is connected to the RF input- TUNER INPUT- of the TV.
So check with your cable operator for the channels and you can connect. however if you are using a digital box then the channels are memorised on the box as only the output of the box is connect to the video/audiop inputs of the TV. if so select line in/video 1/2.
Oct 18, 2011 | Curtis 326A LCD TVDVD Combo
I plugged my cable into television and I can only get one channel even after autoscan
do you have the cable tuner box? Comcast requires a cable box. Don't know about where you are. Conversely I get twelve over the air stations with just a set of rabbit ears... we used to only get four...
Feb 22, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
Auto Scan
haha.......i am finding this really funny....because i am having that problem to and can figure out how to get it fixed.......
Aug 15, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
