Proform CrossTrainer Treadmill Logo
Anonymous Posted on Aug 17, 2009
Belt is slipping
The belt is not frayed and seems in good condition. When I get up to about 3.5 mph it seems to slip. What do I need to do to fix it. I have a Proform Frontrunner PFTL517040
  • Anonymous Aug 17, 2009
    Thanks, The motor seems fine. How hard is it to replace the front roller. It looks a little worn. Does the blet just grip it better when it's new?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Aug 17, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801777
Points
33142
Your macnine needs some maintenance. slippage on the proform is usually due to a worn out front roller and a worn motor driving the belt. both can be replaced. or you may want to find a good used one as many get no use before the optomististic owner decides to sell.
Testimonial: "Thanks for the fast response"
    yes thats exactly what will happen. and regarding replacing the roller it is not a bad job but you will need some tools, or a friend with tools...........lol
2answers
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Hi I have an engine noise coming from the belt area. Like a small ticking/whirring. It is evident when ticking over and seems to reduce when you accelorate. Any help would be greatly received. Thanks.
A slipping belt makes a loud squeaking noise when the engine is running. The belt needs to be changed if it is cracked or fraying on the side, or if it begins to slip.
1helpful
I have a 1999 Mazda 626 5 speed and my rpms seem to always be high weather I'm driving n town, 4th gear 30 mph 2100 rpm, or on the highway 5th gear 70 mph and rpms at 3100. This I'm sure is killing my gas...
check clutch for slipping condition,mayb due to worn clutch disc or a oil contaminated disc or a weak pressure plate not locking disc to flywheel therefore giving u a slipping condition and higher than normal rpms
Belt is slipping,
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill running belt adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
2helpful
Loose air conditioner component may break and
The only air conditioning component I can think of which could cause the serpentine belt to break would be the compressor. If you look under the hood you can see the belt winding around several pulleys of engine parts. The air condition compressor is the part which has two hoses with metal fittings and a wire harness attached to it. When the engine is on the pulley attached to the compressor should be rotating at the same speed as the other pulleys. Keep your hands, clothing and jewelry clear of all moving engine parts. If it is moving at the correct speed it is good, if it is not moving correctly it will cause the belt to slip creating friction until the belt breaks. Once the belt breaks the engine cooling, power steering and battery charging will stop, which will quickly cause the engine to stop working. This could cause engine damage, but it will defiantly strand you with a broken vehicle. If the pulley is working and the air conditioner is working, do not worry about it, but you may want to check the belt with the engine off for cracks or damage. If the belt is slipping and the air condition is not working, the vehicle will need a new compressor, coolant, and possibly a dryer. This could set you back about three hundred dollars. If you do not want to fix the air conditioning and the belt is not slipping run the vehicle as usual if the belt is good. If you do not want to fix the air conditioning and the belt is slipping you may be able to bypass the compressor and use a smaller belt.
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
2answers
I am being told our serpentine belt needs to be replaced. How many miles do they normally last?
depends upon weather, driving conditions, engine options, but the bottom line is the belt will eventually dry out, crack or start peeling (fraying) which should be visible to the naked eye. Also look for oil on belt which can make it slip.There is also an indicator (3 notches looking down from top) which indicates belt wear/stretch. replace belt if outside of indicators.
1helpful
MBK Doodo 125 question
Check the clutch lever free play. It should have about 3/4 inch of movement before any resistance is felt. The speedometer problem may be a bad inner flexible shaft within the speedometer cable. Unscrew the meter end of the cable and pull out the flex shaft--it may be frayed (replace) or just need lubrication.
7helpful
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
