Televison & Video Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model number LCT27HA36..will not turn on????
ILO tv flat screen...model number LCT27HA36..will not turn on????
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Aug 18, 2009
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782746
Points
6681
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to [email protected] if you required further assistance.
Joe Vinton
Level 2:
Champion:
  • Expert 287 Answers
Joe Vinton
Expert
Level 2:
Champion:
Answers
287
Questions
0
Helped
111195
Points
490
I have determined that this is a power supply issue.All info I've been getting indicates that ILO has a parts quality issue.On my 32HA36 I found a few capacitors on the power supply board to have failed.Try unplugging and plug back into the wall outlet several times,each time you do this try turning it on at the controls.This sometimes starts mine up but initially I get the red power light then the green.The only down side is you have to leave the set on 24/7,not good.If this does anything then see if your tv repair person can check that out.You may incur costs more than the set is worth.
  • 1 more comment
  • Joe Vinton Aug 19, 2009
    Replaced the capacitors tonight and my 32HA36 set works now, better than when I purchased it three years ago.
  • Bobbie Armstrong
    Bobbie Armstrong Nov 09, 2012
    I am having the same problem. Can you tell me what Capacitors you replaced?
  • Bobbie Armstrong
    I have the same problem. Can u tell me what capacitors you replaced?
Need a remote for flat screen model #LCT27HA36
GOOGLE THE MODEL NUMBER WITH REMOTE AFTER IT or call customer service for the company who made it.
1helpful
TV won't power up
Likely a failed fluorescent backlight or the inverter that supplies the high voltage to it. I'd like to suggest a potential source for parts or service but the earlier authorized service company was Initial Technology and their webiste is no more so the company is probably defunct. Ilo was sold only by Wal-Mart and our 32HD failed after 6 weeks and when returned after several weeks from repair, had the LCD panel damaged which didn't show up until we tried using it full screen and saw the flaw.
You may have some luck here:
Possible Ilo parts source
Otherwise, I'm afraid your friend is just another victim of a Wal-Mart junk supplier.
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
8helpful
2answers
Ilo lct27ha36
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
ILO TV remote
order the factory remote.800-216-5156
2answers
Ilo LCT27HA36
Contact the manufacturer or go to their web site for manuals etc.
1helpful
8answers
ILO LCT27HA36 No Manual
This is a very low end low quality made TV set. I would suggest you take it back and see if you can exchange it.
From my experience, I would suggest getting a good quality brand name TV set. Most of the Sony LCD TV sets have earphone jacks, external outputs, and come with a full set of instructions. They are also strongly supported for service during the warranty period.
Jerry G.
Ilo lcd tv lct27ha36
I having the same problem. Called the company $80 for a new remote. I only paid $300 for the TV. The company said they have not given out the code for the television. What a CROC! Like the TV, but probably won't buy another.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
