When I go to print, It says spooling but never prints.
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options:
Click Start then select Run
Type the word "net stop spooler" then "net start spooler"
Then unplug and replug the printer while its on.
Josh
Make sure the print job is being sent to the ESP5. Go to control panel/printers and make the ESP5 the default printer.
Make sure operating system spooling and printer are working by right clicking on the printer icon and clicking 'Properties''. Click the 'Print test page button.'
If these steps work ok, make sure the ESP5 is the selected printer when you are attempting to print from your application.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
