Please consult
this page for links to fax error codes for your printer.
In particular, Error 232 yields this info:
Error Code: 232, 233, 234, 235 ECM, 236 ECM, 237
Definitions
A communication failure occurred between the two machines.
The user at the remote machine might have pressed the Stop key.
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
Set the host machine to receive at a slower transmission speed.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
You can also access the home support page for your printer
here., in case you should have further troubles.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
